Match Jobs to Handles
Altair Accelerator tools work to match each license handle to the jobs currently running.
Typically, licenses are from FlexNet Publisher. This matching is based on "soft evidence"; the details of which process has checked out which handle are not available. Matching is based on the following information:
  • The name of the user (normalized to lower case)
  • The name of the host (normalized to lower case, possibly stripped of the domain name)
  • The checkout time compared to the start of the job, with additional uncertainty as FlexNet Publisher reports checkout times to the minute, not to the second.
Matching is especially challenging when jobs of similar age are running on the same machine by the same user.
Despite these difficulties, the matching routines produce useful information that can be used to learn which licenses are actually used by a job. This information is also used by the preemption module.
For information about matching, check the following fields:
lmhandlesall
A list of all matched resources, consisting of one or more triplets of the form resourcename: tokens match_type handle_id"
lmhandlesnru
A list of only the not requested but used (NRU) resources
lmresources
A list of all matched resources, in a older format; use lmhandlesall instead
Summary of Matching Status Values
Legend for Matching Status
This is a Sure match. There is only one handle that matches the job.
This is the Best we can do.
also This could also be a match, but not certain. The number of also matches can be limited by setting the parameter resusermaxmatches. The default value is 6.
group This is a match if Grouped with another handle.
This is a match with an Old job: a job that completed recently.
Not-Requested/Used: Not a match. This handle matches a job that does not request the resource.
Requested/NotUsed: Not a match. This job does not use the resource it requested.
Revoked.
Partial Revocation. This can occur when preemption steals only some of the tokens for a feature, not all. Typically, this is considered an error.
Too early to tell. This applies to jobs that are younger than one minute.
Not a match. This appears to be a handle used outside of the queues.
For additional information about handle matching, and when disabling matching jobs could be needed, refer to Resource/Handle Matching.
