Customize the nc run Command
The nc run command has built-in default features that include checking the validity of the run directory, enabling job profiling, etc. This section describes how the Accelerator administrator can use the file $VOVDIR/local/vncrun.config.tcl to modify some defaults.
This file does not exist by default; it must be created when needed.
The defaults for job characteristics are controlled by entries in the VOV_JOB_DESC array variable. The vncrun.config.tcl file is loaded after the defaults are set; these defaults can be overridden.
For additional information, refer to Define Jobclasses for details about VOV_JOB_DESC.
Examples
When submitting a job, the default is to check for a logical name (equivalence) for the filesystem where the run directory is located. This is controlled by the check,directory slot.
To change the default to not check the directory, add the following to the vncrun.config.tcl file:
set VOV_JOB_DESC(check,directory) 0
When submitting a job, the default is not collecting profile information, because the data can be large, unless the -profile option is used. To make profile collection the default setting, add following to the config file.
set VOV_JOB_DESC(profile) 1
An example file is included below that shows some other commonly-used settings:
# Example content of vncrun.config.tcl
# Other settings that may be useful.
# set VOV_JOB_DESC(priority,default) [VncPolicyUserPriority $username]
# set VOV_JOB_DESC(priority,sched)   $VOV_JOB_DESC(priority,default)
# set VOV_JOB_DESC(priority,exec)    $VOV_JOB_DESC(priority,default)
# set VOV_JOB_DESC(autokill)      0
# set VOV_JOB_DESC(autoforget)    1
# set VOV_JOB_DESC(legalExit)     "0"
# set VOV_JOB_DESC(mailuser)      ""
# set VOV_JOB_DESC(wrapper)       "vw"
# set VOV_JOB_DESC(preemptable)   1
# set VOV_JOB_DESC(profile)       0
# set VOV_JOB_DESC(schedule,date) 0
# set VOV_JOB_DESC(xdur)          -1
Configure Callbacks with vnccallbackaction
In some jobclasses, it may make sense to call custom procedures:
  • Right after a job has been created, i.e. as soon as we know its VovId
  • Right after a job or set has been scheduled
This behavior is controlled by VncCallbackAction. The behavior of this procedure is documented by the following example:
# Example of a jobclass with custom callback to be invoked after the
# job has been created.
set VOV_JOB_DESC(resources) "unix RAM/100"
# ... other jobclass stuff
### Callback section.
proc MySpecialProcedure { jobId } {
   vtk_transition_get $jobId jobInfo
   if { $jobInfo(env) eq "SNAPSHOT" } {
      set jobInfo(env) "MYENV"
      vtk_transition_set $jobId jobInfo
proc MySpecialCleanup { args } {
  VncCallbackAction del run post_create MySpecialProcedure
  VncCallbackAction del run finish      MySpecialCleanup
# VncCallbackAction verbose
# VncCallbackAction quiet
  VncCallbackAction add run post_create   MySpecialProcedure
# VncCallbackAction add run post_schedule MySomeOtherProc
  VncCallbackAction add run finish        MySpecialCleanup
