Accelerator Quick Start
Accelerator has two main commands, nc and ncmgr.
- nc is used to submit, query, and stop jobs. This command can also be invoked as vnc.
- ncmgr is used to start a queue: ncmgr start. By default, the queue (vnc) starts in a server working directory (SWD) that is a subdirectory in $VOVDIR/../../vnc.
The output of ncmgr
start/stop is logged in
${VOVDIR}/local/logs/nc, if it exists.
This page shows the usage messages that are generated by the nc
and
ncmgr
commands.
nc
nc: Usage Message
Usage: nc [-q queuename] <command> [command options]
Queue selection:
The default queue is called "vnc".
You can specify a different queue with the option -q <queuename>
or by setting the environment variable NC_QUEUE.
Commands:
clean Cleanup log files and env files.
debug Show how to run the same job without NetworkComputer.
dispatch Force dispatch of a job to a specific tasker.
forget Forget old jobs from the system.
getfield Get a field for a job.
gui Start a simple graphical interface.
help This help message.
hosts Show farm hosts (also called taskers).
info Get information about a job and its outputs.
list List the jobs in the system.
jobclass List the available job classes.
kerberos Interface to Kerberos (experimental).
modify Modify attributes of scheduled jobs.
monitor Monitor network activity.
rerun Rerun a job already known to the system.
resources Shows resource list and current statistics.
resume Resume a job previously suspended.
run <job> Run a new job (also called 'submit').
preempt Preempt a job.
stop Stop jobs.
submit <job> Same as 'run'.
summary Get a summary report for all my jobs.
suspend Suspend the execution of a job.
taskerlist Show available tasker lists.
wait Wait for a job to complete.
who Report on who is using the system.
why Analyze job status reasons.
Deprecated Commands:
slavelist Show available slave lists.
Unique abbreviations for commands are accepted.
Advanced features:
cmd <command> Execute an arbitrary VOV command in the
context of the NetworkComputer server.
source <file.tcl> Source the given Tcl file.
- Accept commands from stdin.
For more help type:
% nc <command> -h
Copyright (c) 1998-2021, Altair Engineering.
ncmgr
This program manages the vovserver for Accelerator.
Usage
vncmgr: Usage Message
This program manages the vovserver for NetworkComputer.
USAGE:
ncmgr help|info|reset|start|stop|cm [OPTIONS]
ACTIONS:
info [-queue|-q <name>] [-v]
reset [-soft | -hard | -h ]
start [-dir <server_working_dir>] [-force] [-queue|-q <name>]
[-port <port> ] [-webport <port>] [-roport <port>]
[-dbhost <host>] [-dbroot <path>] [-dbport <port>]
[-prod nc|wx|he] [-basequeue <name>]
The default <server_working_dir> is
<...>/vnc.
This is the parent of the configuration (.swd) directory for
the queue.
stop [-force] [-freeze] [-queue|-q <name>] [-writeprdir <dirname>]
-force Do not prompt for confirmation
-freeze Instruct taskers to keep running and wait for a
new server
-writeprdir Writes the PR file to the specified directory
(which is created if necessary)
cm [-queue|-q name] <ACTION> [ARGUMENTS]
Configuration Management. Pass "help" for detailed usage.
EXAMPLES:
% ncmgr
% ncmgr -h
% ncmgr start -queue vnc2
% ncmgr start -port 6699 -queue vnc99
% ncmgr info
% ncmgr reset -soft
% ncmgr reset -hard
% ncmgr cm help
EXAMPLE TO STOP AND RESTART SERVER:
% ncmgr stop -freeze
% ncmgr start -force
% ncmgr stop -freeze -force -writeprdir /tmp/abc123
