SDS Configuration
- SDS configuration directory, at the server working directory (SWD)/config/publishers/sds, for example, ../vnc.swd/config/publishers/sds
- SDS configuration file in the SDS configuration directory, sds.cfg
enabled = 0;
kafka_servers = "";
format = "json";
site = "";
group = "";
events = {
project = {
schemaId = 0;
topic = "vov-projects";
taskers = {
schemaId = 0;
topic = "vov-metrics-taskers";
jobs = {
schemaId = 0;
topic = "vov-metrics-jobs";
scheduler = {
schemaId = 0;
topic = "vov-metrics-scheduler";
Configuration File Parameters
Parameter | Values | Default | Description |
enabled | 0 or 1 | 0 | Disable/enable SDS on startup/readconfig |
format |
"json" "confluent" |
"json" | Specifies the Kafka payload format to use, "confluent" = confluent Avro dialect with the schema registry id |
site | string | "" | User definable string to be delivered with the project record |
group | string | "" | User definable string to be delivered with the project record |
debug | 0 or 1 | 0 | Disable/enable SDS debug logging on startup/readconfig |
Event Specific Configurable Parameters in sds.cfg
Each event has its own configuration section in the config file, for example, for the project event:
events = {
project = {
schemaId = 0;
schemaId | integer | 0 | N < 0, do not publish this event N = 0, publish using single object encoding N > 0, publish using Confluent encoding where N is the schema's registry id |
topic | string | see event table | The name of the Kafka topic to which these events are published. |
format |
"" "json" "confluent" |
"" | Overrides format for this event "" = use format specified at the overall service level |
Kafka Configuration
# kafka properties forwarded to rdkafka library for client config
kafka_properties = {
security = {
protocol = "ssl", # security.protocol=ssl
ssl = {
ca = {
location = "/home/rhenry/Proj/confluent/ssl2/ca-cert" # ssl.ca.location=/home/rhenry/Proj/confluent/ssl2/ca-cert
certificate = {
location = "/home/rhenry/Proj/confluent/ssl2/client_hecto_client.pem" # ssl.certificate.location
key = {
location = "/home/rhenry/Proj/confluent/ssl2/client_hecto_client.key", # ssl.key.location
password = "abcdefgh" # ssl.key.password
Kafka uses security.protocol = "ssl"
However, there is flexibity to include an equivalent as security { protocol =
"ssl" }
The vovserver/SDS is passing the configuration through to the underlying Kafka libraries and network layer, making this feasible.
Change the Config File for the First Time
In order to use SDS for the first time, the user must perform the following operations:
Set the kafka_servers parameter in the
sds.cfg file to the bootstrap server(s) for their kafka
installation; for example,
kafka_servers = "kafkahost:9092"
orkafka_servers = "kafkahost1:9092,kafkahost2:9092"
If publishing using the Confluent Schema Registry, then the following steps are
also needed:
- Upload the schema files to the schema registry and note the IDs assigned to each schema.
- Assign the schema registry IDs discovered in step 1 to the events in the sds.cfg file (see Event specific configuration below)
For the initial release the Kafka published events are:
Event Name | Description | Schema File | Default Topic |
project | (relatively) Static project information that may be useful to join with time series data | vov-projects | |
taskers | Metrics related to the state and capacity of the taskers | metrics.taskers.avsc | vov-metrics-taskers |
jobs | Metrics related to the number of jobs in specific states and rate of dispatch/completion | metrics.jobs.avsc | vov-metrics-jobs |
scheduler | Metrics related to scheduler performance, sizes, clients, innerloop timers | metrics.scheduler.avsc | vov-metrics-scheduler |
Changing the Config File at Run Time
The SDS configuration may be changed while the server is running.
Troubleshooting
%3|1610382360.585|FAIL|rdkafka#producer-1| [thrd:foo:9092/bootstrap]: foo:9092/bootstrap: Failed to resolve 'foo:9092': Temporary failure in name resolution (after 1033ms in state CONNECT)
%3|1610382360.585|ERROR|rdkafka#producer-1| [thrd:foo:9092/bootstrap]: 1/1 brokers are down
%3|1610382363.544|FAIL|rdkafka#producer-1| [thrd:foo:9092/bootstrap]: foo:9092/bootstrap: Failed to resolve 'foo:9092': Temporary failure in name resolution (after 993ms in state CONNECT, 1 identical error(s) suppressed)
If the kafka servers are not running or reachable, the server log will contain entries like the following:
%3|1610383215.659|FAIL|rdkafka#producer-2| [thrd:hecto:9092/bootstrap]: hecto:9092/bootstrap: Connect to ipv4#127.0.1.1:9092 failed: Connection refused (after 0ms in state CONNECT, 1 identical error(s) suppressed)
