Manage Tasker Lists
A tasker list is a named, ordered list of taskers. Tasker lists can be used to enhance performance or restrict usage.
- Make the scheduler more efficient on large farms.
- Pack jobs more tightly on the farm machines.
- Restrict jobs to selected taskers.
Every vovserver has at least one tasker list named default, which includes all the taskers in the system. The order of the taskers is determined by the connection order unless modified by the commands shown below. The default list cannot be deleted or recreated; taskers can be reordered in the default list.
An administrator can create, modify and delete tasker lists with the utility vovtaskerlist.
vovtaskerlist
Manipulate tasker lists.
vovtaskerlist: Usage Message
DESCRIPTION:
USAGE:
% vovtaskerlist ACTION [OPTIONS]
OPTIONS:
-h -- This help
-v -- Increase verbosity
Actions:
create -- Create a new list
append
first
last
get -- Get taskers in a list
list -- List all tasker lists
delete -- Delete specified tasker list
bigram -- Create list of taskers with a lot of ram
smallram -- Create list of taskers with little ram
Note: actions can also have a dash (list and -list)
EXAMPLES:
% vovtaskerlist create planets "pluto jupiter uranus"
% vovtaskerlist get planets
% vovtaskerlist list
% vovtaskerlist first planets jupiter
% vovtaskerlist last planets jupiter
% vovtaskerlist delete planets
% vovtaskerlist -bigram 10000 ;; Make a list of taskers with more
than 10GB of RAM
% vovtaskerlist -smallram 2000 ;; Make list of all taskers with less
than 2GB of RAM
nc taskerlist
Any user can view the tasker lists with the nc taskerlist command.
nc: Usage Message
NC SLAVELIST
Support slave lists.
SlaveLists are named, ordered lists of slaves.
USAGE:
% nc slavelist [OPTIONS]
OPTIONS:
-h -- This help
-v -- Increase verbosity,
-list -- List all available slavelists
-get LIST -- Get the ordered slaves in the
specified LIST
ADDITIONAL INFO:
To manage the slave lists, you have to be ADMIN
and you can use the vovslavelist utility.
EXAMPLES:
% nc slavelist -list
% nc slavelist -get NAMEOFLIST
% nc run -r SlaveList:NAMEOFLIST ... -- myjob
Create and Delete Taskerlists
big
that contains five
machines:% vovproject enable vnc
% vovtaskerlist create big "lnxbig01 lnxbig02 lnxbig03"
% vovtaskerlist append big "lnxbig04 lnxbig05"
% vovtaskerlist delete big
first
or last
: to the beginning or to the end of
the list, respectively. These commands can also be used on the default list.
% vovtaskerlist first big lnxbig05
% $VOVDIR last big lnxbig01
The vtk API for Tasker Lists
vtk_taskerlist_create LISTNAME "list of taskers"
vtk_taskerlist_append LISTNAME "list of taskers"
vtk_taskerlist_first LISTNAME "list of taskers"
vtk_taskerlist_last LISTNAME "list of taskers"
vtk_taskerlist_get LISTNAME
vtk_taskerlist_delete LISTNAME
vtk_taskerlist_list
% vovsh -x 'vtk_taskerlist_create reverse [lreverse [vovtaskerlist_get default]]'
Choose a Tasker List for a Job
% nc run -r TaskerList:big -- sleep 100
If the specified list does not exist, the job will not run.
