Clean Up Log Files
All log files are normally stored under the subdirectory ./vnc_logs. To remove all obsolete log files in the current working directory, use the nc clean command.
nc clean
This command cleans up obsolete log files and environment files that have been generated by jobs submitted to the scheduler.
nc: Usage Message
NC CLEAN:
By default the command cleans the current working directory
(i.e. removes logs and environment files of the jobs executed in the
current working directory).
If a list of directories is provided, the command will clean up
the files in those directories instead.
USAGE:
% nc clean [OPTIONS] [LIST_OF_DIRS]
OPTIONS:
-nozap -- Do not 'zap' isolated nodes (see man vsz for more info).
In this way, the cleaning of the current directory
may proceed faster.
-zap -- Do 'zap' of isolated nodes (see man vsz for more info).
-deep N -- Clean the jobs from all directories in which the user
has executed jobs in the past N days. The directories
are found from the journals.
-dir <dir> -- Specify additional paths to check.
-P PERIOD -- Install a periodic job to run the cleaning automatically.
-R -- Clean the directories recursively.
-v -- Increase verbosity.
-h -- This help.
EXAMPLES:
% nc clean -h
% nc clean
% nc clean -dir /tools/logs/VNC_LOGS -dir /scratch/logs/VNC
% nc clean . /tools/logs/VNC_LOGS /scratch/logs/VNC
% nc clean -zap
% nc clean -deep 10
% nc clean -deep 3 -P 3d
% nc clean -R
% nc clean -nozap
% nc clean -deep 10
% nc clean -P 1d
