License Keys
Runtime License Key Files
Runtime legacy key files can be installed either in the local directory of the installation tree or in the product-specific server working directory (SWD). Runtime legacy key files installed in the local directory must be in the format of license.productcode.key, where productcode is one of "lm" or "nc".
Runtime legacy key files that are installed in the SWD can use this format or the name license.key. For example, for Monitor, use the file licmon.swd/license.key and for Accelerator use vnc.swd/license.key.
Note: The SWD is created upon product start up, so ensure the product has been started before attempting to put a SWD license key file in place.
The vovserver searches for the keyfile license as follows:
  1. The file named by the environment variable VOV_LICENSE_KEY, if set. This should be defined in the project's setup.tcl file.
  2. SWD/license.<productcode>.key
  3. SWD/license.key
  4. $VOVDIR/local/license.<productcode>.key
The Runtime legacy key files encodes the host IDs of the hosts where the application is allowed to execute and the maximum allowed number of tokens provided by the license.
The following is an example of one such Runtime legacy key file, to enable an Accelerator project (product: nc) on port 6271 on a machine called mac05 for up to 100 slots (license for: 100 slots).
Example Runtime legacy key file:
#    -- VOV License  Key  Information --
#    License S/N: 20161110a
#    VovVersion:  2020.1
#    Product:     nc
#    Licensed to: rtda
#    For host id: MAC:00:25:00:9f:76:68
#    For host:    mac05
#    For port:    6271
#    License for: 100 slots
#    StartDate:   Tue Nov 10 10:29:25 2019
#    Expiration:  Thu Dec 31 21:00:00 2020
EFIFFF`gjdCEceFDdd`ekgMDEDMEBGheee`ejcGEiadeifogJA
iel`neC@`eca@EHAMDFAgeD@LENFedfdCEceJE`angFE`dn`AA
L@AAADNGkfA@IADEBAkaB@o`KEceADEFJGlfnbJEd`bdFBeeod
CDeehgidbaOEjgMENE`ejcOEhdeeieedadceMEGEcc@@AECEle
bdHDCEfbDEEBEDICIEIFAFEAG@oeLACDndLEDENAg`KFhgfdAA
BDddodCEbeJBddne@DFFaejeODjdD@AEAALDAAKGk`BDofCGl`
dek`@@OFidd`aeedadheheoeACGEee`eieedadeeceLEAEIGNG
`e
Multiple Runtime legacy key files can be concatenated into the same file and the combined value of all the license keys will be used by the application. The serial numbers of such licenses must be distinct. You must leave the comment lines that precede the encrypted section.
This licensing mode is activated if one of these conditions is true:
  • If the license.key file is present, even if it is empty or invalid
  • If the variable RLM_LICENSE is not defined
If the software is using the license key, vovserver manages the licenses for any vovtasker that connects it. The vovtaskers do not read the Runtime legacy key files.
Checking the Runtime Legacy Key File
An easy way to verify a license key file is with the utility vovreadlicutil.
vovreadlicutil
usage: vovreadlicutil [-f filename] [-P port] [-p product] [-V version]
                    [-I hostid] [-tv]
   -f:         Specify a license file.
   -P:         Specify port number.
   -p:         Product name to test (nc,lm,ft,lam,wa,...)
   -V:         Release date of version to test, in YYYY.MM format
   -I:         HostId to test
   -t:         Generate Tcl array with license info
   -v:         Print version.
The typical use is the following:
> source /<install_path>/<version>/<platform>/common/etc/vovrc.csh
                    % vovreadlicutil -p nc -f vnc.swd/license.key
                        License S/N: 20160909T153538
                        VovVersion:  2020.1
                        Product:     nc
                        Licensed to: Altair
                        For host:    mac05
                        For port:    6271
                        License for: 40 slots
                        StartDate:   Thu Sep  9 06:35:38 2019
                        Expiration:  Fri Dec 31 12:00:00 2021
                    vovreadlicutil Nov 14 14:11:27 Valid for product nc
                    vovreadlicutil Nov 14 14:11:27 Valid for this host MAC:00:25:00:9f:76:68
                    vovreadlicutil Nov 14 14:11:27 Valid for port 6271
                    vovreadlicutil Nov 14 14:11:27 Valid for version 2019.01
                    vovreadlicutil Nov 14 14:11:27 Valid expiration (still 112d21h to go)
                    vovreadlicutil Nov 14 14:11:27 The combined license is:
                    VovVersion:  2020.1
                    Product:     nc
                    Licensed to: Altair
                    For host:    mac05
                    For port:    6271
