When you select a license server, take the following resources into consideration:
- Sockets
- Each licensed application connected to a license server uses one or more
sockets. The number of sockets available to the license server is
defined by the per-process system limit for file descriptors. The total
number of sockets used by the license server is slightly larger than the
total number needed by the licensed applications that are served by it.
If the number of sockets required by the license server on a single
machine becomes excessive, the license file can be split into more than
one file, on multiple servers.
- CPU Time
- For small groups of clients, the license server uses very little CPU
time, perhaps only a few seconds of CPU time over many days. For a large
number of clients, or for high check-out/check-in activity levels, the
amount of CPU time consumed by the server may become significant. If
such a situation occurs, you may need to ensure that the server machine
you select has an adequate number of CPU cycles.
- Disk Space
- The license package requires about 100 MB of disk space to install. The
log files created by the system vary in size, depending on activity. It
is recommended that the file system where the log files are to be
written has sufficient space to store many days or months worth of log
files. There should be a minimum of 500 MB of space for this
purpose.
- Memory
- The license manager daemon uses a variable amount of system RAM. Typical
memory usage is in the range of 15-50 MB resident and a virtual set size
of 90-150 MB. For very busy servers with a lot of clients the Resident
set size could grow to several 100MB.
- Network Bandwidth
- The licensing process requires a fairly small amount of network
bandwidth. Typical networks running over Ethernet should not produce any
problems. The system uses TCP/IP for all communications on the
configured port, and uses this one port for all communications.
- Remote Mounted Disks
- Altair highly recommends that the software and all logs reside on disks
local to the license server. Testing is only done on local
disks/directories. Although remote ones may work, they are not
tested
- Redundant License Servers
- The system supports both HAL (High Availability) servers and server
lists. HAL servers act as a quorum to serve up one pool of licenses,
allowing one machine to go down without affecting license availability.
Multiple independent servers can be used to split up the total license
pool and clients can access them via a server list.
