Build the Flow
Now that you have a job description, you need to build the flow with the vovbuild program.
% vovbuild
.... # 4 dots, one per job
Building the flow is different from running it. The jobs in the flow may take seconds or days to execute, but building the flow is normally a rather quick step. Building the flow is building the dependency graph, not running the programs registered into the graph.
After the vovbuild is done, you must double click the System:nodes set in the Set Browser to get the console to refresh the Set Viewer with the current graph.
Notice that the dependency ordering of the jobs in the graph has been created properly, even though the jobs in the FDL file were entered without an order.
Notice that the top node is brown, to indicate that file aa is missing. The flow building discovered that file aa is not present and marks the file to have the MISSING status. The other nodes are purple to indicate that they are INVALID.
