Command Line Setup
An advanced user may want to use the command line to setup LicManager. All necessary files are in the directory licmon.swd/licmgr and the utility to use is called ftlm_licmgr_init.
ftlm_licmgr_init: Usage Message
DESCRIPTION:
Initialize the licmgr/current directory for LicenseMonitor.
This is the directory where copies of the active licenses
are stored.
This script is normally called automatically by ftlm_licmgr.cgi.
OPTIONS:
-tag TAG -- Only update for specified tag
-cvs -- Initialize the CVS vault
-templates -- Initialize the templates for each known tag
-reread -- Reread configuration files.
-v -- Increase verbosity
-h -- This help message
EXAMPLES:
% ftlm_licmgr_init -cvs
% ftlm_licmgr_init -templates
% ftlm_licmgr_init -templates -tag MGC
- Initialize CVS.
% ftlm_licmgr_init -initcvs
This step may fail if CVS is not available on your Monitor server machine.
- Create the initial templates.
- Edit the templates to activate them. This is mostly done manually, since a
lot of the information required to start and stop the daemons is not
automatically retrievable from lmstat.
% ftlm_licmgr_init -f
- Create the jobs in the system. This step needs to be repeated each time the configuration files are changed.
