Basic Operations and Setup (Admin Only)
This section is organized into a series of instructions designed to guide you through the beginning steps of setting up your Monitor system. It’s not meant to be a complete administrator guide, but it is designed for system administrators and for most of the steps here, you will need admin permissions.
