Check your Monitor System (Admin Only)
  1. Log in to Monitor.
  2. Go to the Admin menu and select the Tasks option.
    Figure 1. Job Status List
  3. Check the job status.
    • If it shows green, it’s done running.
    • If it shows waiting, reload Monitor in 30 seconds.
    • If job status shows red (failed), click on the job name, and scroll down to explanation of why this job is failed.
  4. Check to see if your home page shows checkouts.
