Standalone Configuration for Parsing Debug Logs – File-Based Configuration
To add denial data from a debug log to an existing tag (standalone configuration), perform the following steps:
View new features for Monitor 2022.1.1.
A real time software license monitoring and management tool.
Currently there are no Monitor tutorials available.
Monitor monitors tools with licenses using live sampling and debug logs for denials, and it monitors tools with no licenses using wrapper scrips and a monitoring agent.
All Altair Accelerator software products are based on a client/server architecture and have three main components: a server, daemons and taskers.
The installation section is divided into five sections, an introduction with system requirements, and four different types of installations.
We suggest as first steps that you check Monitor to be sure it’s running properly and then perform a few basic tasks to get a feel for the system.
This section explains how to use Monitor to answer common questions. In most cases, there isn’t one answer to a question. Some investigation is required.
Altair Monitor is a software license tracking tool that reports current and historical license utilization. The license managers that Monitor supports includes FlexNet Publisher, Reprise, LUM, and unlicensed tools. The primary user interface for accessing Monitor is a web interface.
Add_DEBUG_LOG </path/to/log> -tag <TAG> [options]
add_DEBUG_LOG
[options]
Add_DEBUG_LOG </Users/ybouvron/rtda/Cadence/@DATE@.log> -tag
CAD_LOG -tz PST8PDT -minPeriod 12h -maxPeriod 1d -autokill
2h
Configure, Manage and Run Accelerator
Configure the Network, License and Security
Configure Monitoring of Software Utilization
Hierarchical Scheduling
License Allocation across Enterprise
Hardware Emulator Resource Optimizer
