How do I Make a Forecast and Plan for the Next Quarter? (Admin)
From the History menu, click the Usage drop down menu and select Efficiency Statistics and/or Detailed Plots, so you can evaluate usage over time. You can extrapolate data from these reports on your current use and make predictions. In the following example, you can view the historical use of a feature.
Figure 1. Feature Efficiency Statistics
You can also create reports, which return useful information and help with monitoring and planning. You might create a group (which is a selection of users) and track a project (which is selection of users that you track). Projects take time to yield useful information. When you set these up, you can see the department/site/group/team and the resources used.
