Install Monitor
- Once the download is complete, right-click on the bundle win64_bundle.zip, and select Extract.
Click Extract again.
The files will extract to location of the zip file. The file will open.
Double-click on install.bat.
Figure 1. Altair Accelerator Product Installation Utility - If this is an upgrade, in the Existing Installation Directory Field, enter the path to the existing installation; if this is a new installation, leave this field blank.
- In the New Installation Directory field, enter your chosen path. If you are updating a file, we recommend you enter the date of the update in that file heading.
- If you have a Monitor license, put the port@host in the appropriate section
- Click Start Installation.
- Click Exit to close the GUI.
