Add a License Monitor
  1. To add a license monitor, go to the Admin tab, and select Monitors from the menu bar.
    Figure 1. Adding a New License Monitor
  2. Enter details for at least sections 1-4.
    1. Select monitor type.
    2. Specify a unique tag name.
    3. Enter license file locations.
    4. Enter full path to status command.
  3. On the bottom, click Add New Monitor.
  4. Go to Home tab.
    The current checkouts should be populating shortly, within 30 seconds.
  5. For Windows users, we recommend setting up Monitor as a service, if you haven’t done so already. See Set Up Monitor as a Service – Windows Only.
