Change the Sampling Period for One Instance
To change the sampling period, perform the following steps:
  1. Go to Admin tab and the Monitors option.
  2. Scroll down to the last section, Section 8 Periods.
    Figure 1. Admin Page – Monitor Option
  3. Change the timing of the Usage sampling option to the desired minimum.
