</path/to/log> |
The first argument must be a path to an CodeMeterâ„¢ log file. For a
rotating log, the name specified must be in the form of
<fileName>.@LATEST@.log. See Debug Log Monitoring for more
details. |
-tag <TAG> |
Specify the TAG to identify the license server. The TAG may contain
only alphanumeric characters and underscores (_). The use of upper case
characters is recommended for style purposes. |
-tz, -timezone |
Set to timezone which was used to generate the debug log. Ex: PST8PDT.
If debug log was generated in the same timezone as the Monitor server, leave
blank. |
-checkouts |
Extract checkout information from debug log. This can be used to
monitor checkouts that are shorter in duration than the sampling
rate. |
-host |
If monitoring debug logs from triads, use this option to denote the
server from which the data originates. |
-minPeriod <TIMESPEC> |
Minimum sampling period. |
-maxPeriod <TIMESPEC> |
Maximum sampling period. |
-autokill <TIMESPEC> |
Kill parsing job after specified time. |
-usekeystore |
Use DSLS key store file ($SWD/vovlmd/TAGNAME.ks) for
authentication. |
-robust |
Warn and ignore unparsable license usage output lines. |
