Filesystem Monitoring
Similar to the Hosts List page, the Filesystems page shows information about the various filesystems that are present across all of the hosts that are being monitored.
This can be useful in identifying filesystems that are low on available disk space. This page color-codes filesystems, which provides easy to use filesytem identifiers that requires little disk space.
The File Systems option shows a list of file systems that are reported for all machines which have monitor agents running. Like the "Hosts" page, the "Filesystems" page shows information about the various filesystems that are present across all the hosts that are being monitored.
Figure 1. File Systems Page: Host Information
The following columns are available on this table:
Fs Id
The file server ID.
File Server Host
The file server host name.
File System
The type of file system.
FS Type
The file server type.
Clock Offset
The difference between your machine’s clock time and the file server’s clock time.
Quota
The disk quota is a limit set by a system administrator that restricts certain aspects of file system usage on modern operating systems. The function of using disk quotas is to allocate limited disk space in a reasonable way. If it shows “no,” then no quotas are set on your machine.
Total Space (MB)
Total available space on the file system.
Free Space (MB)
Total space available left for use.
Free Space (%)
Percent of available space on the file system.
