Host Monitoring
The Hosts List page shows information about each host on which an agent is running:
Figure 1. Host List Page: Network Information
- Hostname
- The host file name.
- Domain
- The domain name.
- Machine
- The type of the machine.
- Arch
- This is the architecture, the machine’s platform.
- CPUs
- The number of CPUs running on your machine.
- Speed (MHz)
- Processing speed.
- RAM (MB)
- Read access memory.
- IP address
- The IP Address of your machine.
- Rx (KB/s)
- Received from the server being monitored in Kilobytes per second.
- Tx (KB/s)
- Transmitted from this server being monitored in Kilobytes per second.
- Load
- The Machine Load.
- Uptime
- The time that your machine has been up and running.
- Idle Time
- The time the machine is running operations and applications.
- Clock Offset
- This shows if your machine and your system clock are in sync.
