Create Batch Reports (via Command Line)
ftlm_batch_report
ftlm_batch_report: Usage Message
DESCRIPTION:
    ftlm_batch_report [OPTIONS]
OPTIONS: (Note: when generating a report, for an option that does not require
          a value, it is recommended that a boolean value 1|0 is provided to
          explicitly enable or disable it to avoid confusion, e.g. using
          "-utilPlotShowQueued 1" instead of "-utilPlotShowQueued" to enable
          the tokens queued plot, and using "-utilPlotShowQueued 0" to disable
          the tokens queued plot. No need to guess the default setup for this
          option which may change overtime!)
    -h                      -- Help (usage statement)
    -v                      -- Increase verbosity
    -inputFile <INFILE>     -- Specify all options in a file (use
                             $env(VOVDIR)/etc/config/lm/ftlm_batch_report.tmpl
                               as template),
                               or specify individually as follows
    -tag <TAGS>             -- Specify a comma-separated list of tags
    -feature <FEATURES>     -- Specify a comma-separated list of features
    -user <USERS>           -- Specify a comma-separated list of users
    -host <HOSTS>           -- Specify a comma-separated list of hosts
    -account <ACCOUNTS>     -- Specify a comma-separated list of accounts
                               (projects)
    -version <VERSIONS>     -- Specify a comma-separated list of versions
    -accounting_* <FIELDS>  -- Specify a comma-separated list of accounting
                               fields (custom groups)
    -negate_*               -- Negate corresponding filter spec (e.g. tag,
                               feature, user, host, etc ...)
    -interval <INTERVAL>    -- Choose time interval of report (default: "last
                               quarter"). Symbolic values include "today" and
                               "yesterday", as well as "this" or "last" in
                               combination with one of "week", "month",
                               "quarter", or "year".
                               Custom intervals are acceptable in the
                               following formats:
                                   20120101-20120331
                                   20110101T000000-20110131T235959
    -workweek               -- Apply workweek filtering to specified reports
    -limit <NUM>            -- Default limit for returned rows in all tables
                               (default: 100)
    -title <STRING>         -- Specify a report title string
    -outputFormat html|csv|raw -- Specify whether outputting HTML or CSV
                                  (default: html)
    -origin <ORIGIN>        -- Choose data origin
                               ORIGIN : samples, logs (default: samples)
    -breakdownByFeature     -- Break down reporting by feature instead of
                               by tag
    -showAllReports         -- Enable all types of reports
    -showSql 1|2|3          -- Show SQL debugging output:
                               1 shows query
                               2 shows results
                               3 shows explain
    -notUseDataView         -- Do not use materialized view for daily report
    -showFeatureStats               -- Enable daily feature statistics table
    -showFeatureStatsPlot           -- Enable daily feature statistics plot
    -showEfficiencyStats            -- Enable efficiency statistics table
    -showEfficiencyHistogram        -- Enable concurrent utilization chart
    -showCheckoutStats              -- Enable checkout statistics table
    -showCheckoutDetails            -- Enable checkout details table
    -showCheckoutPieCharts          -- Enable checkout pie charts
    -showDenialPieCharts            -- Enable denial pie charts
    -showUtilizationPlot            -- Enable utilization plot
    -showDenialStats                -- Enable denials statistics table
    -showDenialDetails              -- Enable denials details table
    -showDenialPlot                 -- Enable denials plot
    -showHeatmaps                   -- Enable heatmap(s)
    -showUsageComparisonPlot        -- Enable usage comparison plot
    -showCheckoutDurationHistogram  -- Enable checkout duration histogram
    -showUsageTrends                -- Enable usage trends table
    -sort*By <FIELD>                -- Sort corresponding table by
    -limit*  <NUM>                  -- Limit corresponding table rows
    -glitch  <TIMESPEC>             -- Specify glitch width to ignore
    -denPlotBinInterval             -- Override dynamic averaging window
    -utilPlotYmax                   -- Override dynamic y-axis max
    -utilPlotHeight                 -- Specify custom plot height
    -utilPlotWidth                  -- Specify custom plot width
    -utilPlotBinInterval            -- Override dynamic averaging window
    -utilPlotHideCapacity           -- Hide capacity area on plot
    -utilPlotHideDetail             -- Hide detail line on plot
    -utilPlotHideAverage            -- Hide average usage line on plot
    -utilPlotShowPeak               -- Show peak usage line on plot
    -utilPlotShowCurrent            -- Show currently usage line on plot
    -utilPlotShowReservations       -- Show reservation line on plot
    -utilPlotShowFuture             -- Show future line on plot
    -utilPlotShowQueued             -- Show separate queued item plot
    -utilPlotHideQueuedCapacity     -- Hide capacity with queued on plot
    -utilPlotShowQueuedPeak         -- Show peak with queued on plot
    -utilPlotLegendLocation         -- Specify location of legend with
                                       respect to plot (s|e, default: s)
    -featureStatsPlotShowUsage      -- Show usage plot on daily feature stats
    -featureStatsPlotShowQueued     -- Show queued requests plot on daily
                                       feature stats
    -featureStatsPlotShowDenial     -- Show denials plot on daily feature
                                       stats
    -usageComparisonPlotStack       -- Stack items to show total summed usage
    -usageComparisonPlotStyle <STYLE> -- Specify plot style (default: line)
                                         Supported styles: line, linefill,
                                         step, stepfill
    -usageComparisonPlotType   <TYPE> -- The type of smoothing for the plot
                                         (default: max)
                                         Supported types: max, avg
    -usageTrendsBreakdown           -- Specify report breakdown interval
                                       (default: weekly)
                                       Supported breakdowns: hourly, daily,
                                       weekly, biweekly, semimonthly,
                                       monthly, quarterly
    -usageTrendsHideBreakdown       -- Hide statistics for breakdown segments
    -usageTrendsHideAvg             -- Hide average statistics
    -usageTrendsHidePeak            -- Hide peak statistics
    -usageTrendsShowReservations    -- Include reservation checkouts in
                                       statistics.
    -checkoutStatsShowRes           -- Include reservation checkouts in
                                       statistics.
    -checkoutStatsShowIdle          -- Include idle users in statistics.
    -includeIdleFeatures        -- Include idle features in efficiency
                                   statistics.
    -includeIdleTime            -- Include idle time in efficiency statistics
    -efficiencyHistogramMaxBars -- Specify maximum number of bars to show on
                                   histogram
    -heatmapShowNumbers 1|0     -- Show heatmap numbers (default: 1)
    -heatmapType <TYPES>        -- Specify types of heatmaps
                                   (comma-separated list)
                                   TYPES : usage, checkouts, checkins, denials
                                   (default: usage)
    -checkoutPieChartType <TYPES>   -- Specify types of pie charts
                                       TYPE : count, duration
                                       (default: count,duration)
    -checkoutPieChartHeight         -- Specify custom piechart height
    -checkoutPieChartWidth          -- Specify custom piechart width
    -denialPieChartHeight           -- Specify custom piechart height
    -denialPieChartWidth            -- Specify custom piechart width
    -reportCheckoutStatsBy <VALUES> -- Specify how to report checkout
                                       statistics by (comma-separated list)
                                   VALUES : tag, taggedfeature, taggeduser,
                                   feature, featureuser, user, userhost,
                                   host, account, version, accounting_*,
                                   user_accounting_*, host_accounting_*
                                   (default: user)
    -reportDenialStatsBy <VALUES>   -- Specify how to report denials
                                   feature, featureuser, user, userhost, host,
                                   accounting_*, user_accounting_*,
                                   host_accounting_* (default: user)
    -reportCheckoutPieChartsBy <VALUES> -- Specify how to report checkout pie
                                           charts by (comma-separated list)
                                   feature, featureuser, user, userhost, host, account,
                                   version, accounting_*, user_accounting_*,
    -reportDenialPieChartsBy <VALUES> -- Specify how to report denial pie
    -reportUsageComparisonPlotBy <VALUES> -- Specify how to report usage
                                             comparison plot by
    -reportUsageTrendsBy <VALUES> -- Specify how to report usage trends by
                                   host_accounting_n* (default: user)
    -extractImages <INFILE> -- Extract PNG images from the plot data
                               contained in the specified batch report HTML
                               file.  Image files are exported to the current
                               working directory.
    -replaceImages <INFILE> [OUTFILE] -- Extract PNG images from the plot
                                         data contained in the specified batch
                                         report HTML file, replace the
                                         corresponding dynamic image elements
                                         in the file, and clean up the
                                         plot-rendering javascript code.
                                         This will reduce the size of the
                                         report file, but some dynamic
                                         features will be unavailable.
                                         Default output file will be based
                                         upon the name of the input file,
                                         with '-static' appended to the name
                                         (eg myreport-static.html), and will
                                         be generated in the current working
                                         directory. Image files are also
                                         exported to the current working
                                         directory and will be linked as such
                                         in the output file.
    -staticImages 1|0           -- Instructs whether the batch report be
                                   generated as static images for plots. If
                                   set to 1, it is equivalent to first
                                   generating the report normally, then
                                   calling it again with the option
                                   "-replaceImages" to create a batch report
                                   output file that contains references to
                                   static images in one step. See
                                   -replaceImages above for more details on
                                   this functionality.
                                   Requires the -outputFile option.
    -outputFile <OUTFILE>       -- Specify output file.
                                   Default is to output to stdout.
    -script <PATH>              -- Specify a legacy script to use
            The search path for the script includes the following directories:
                1) .
                2) $VOV_REPORT_DIR
                3) $VOVDIR/local/lm/reports
                4) $VOVDIR/etc/lm/reports
            The argument passed to the script is
                "tag=$tag&interval=$interval"
            which is to be interpreted as a query string.
            Look in $VOVDIR/etc/lm/reports for examples.
EXAMPLES:
    % ftlm_batch_report -h
    % ftlm_batch_report -inputFile my_lmreport_ctl.txt
    % ftlm_batch_report -script report_tag.tcl -tag ABC -interval "Sep 2008"
    % ftlm_batch_report -interval 20110101-20110131 -tag EDA
                          -feature MATLAB -showFeatureStats 1
    % ftlm_batch_report -interval Yesterday -tag EDA
                          -feature MATLAB -showUtilizationPlot 1
                          -staticImages 1 -outputFile dailyutilplot.html
