Failover Server Candidates
If a server crashes suddenly, VOV has the capability to start a replacement server on a pre-selected host. This capability requires that the pre-selected host is configured as a failover server.
View new features for VOV Subsystem 2022.1.1.
Discover the workspace, licensing and installation, and training.
Discover VOV Subsystem functionality with interactive tutorials.
This manual provides information about managing a VOV project, including starting the server and connecting computing resources such as computers and licenses.
All of Altair Accelerator's products are based on a client/server architecture to support concurrent activities, team coordination, distributed data management, and distributed processing. The program vovserver runs in the background as a service to implement the main product features. It is the server.
A "project" is a named collection of jobs, together with all the files that are used and produced by those jobs. The contents of VOV projects can be custom organized.
The VOV Registry contains the list of all projects known to an installation of Altair Accelerator software. The registry is used by the vovproject command, and stores metadata such as the host machine and port number of a project.
If the vovserver crashes, after a period of time, the vovtasker process on each machine notices that it has had no contact from the server, and it initiates a server machine election.
Crash Recovery Mode is activated the next time the server is restarted, if the server was not shut down cleanly. Crash Recovery Mode is part of the Failover Server capability of VOV, which is mainly used in Accelerator. This capability allows VOV to start a new server to manage the queue of a server which has crashed unexpectedly.
The files used in a project reside in one or more directories spread all around your filesystems. Each logical name defined in the equiv.tcl file implicitly declares the root of a workspace. You can browse the workspaces using the browser interface.
A tasker is a VOV client that provides computing resources, specifically CPU cycles, to the vovserver.
FlowTracer can be used also as a front end to an existing batch processing system (BPS), for example, Accelerator, LSF, SGE, SGEEE, etc.
Altair Accelerator includes a subsystem for managing computing resources. This allows the design team to factor in various constraints regarding hardware and software resources, as well as site policy constraints.
This document is a collection of techniques that have proven to be useful when applying FlowTracer in Electronic Design Automation.
% vovserverdir -p servercandidates.tcl
/home/john/vov/myProject.swd/servercandidates.tcl
set ServerCandidates {
host1
host2
host3
% cd `vovserverdir -p .`
% mkdir autostart
% cp $VOVDIR/etc/autostart/failover.csh autostart/failover.csh
% chmod a+x autostart/failover.csh
% vovautostart
% vovtaskermgr show -taskergroups
ID taskername hostname taskergroup
000404374 localhost-2 titanus g1
000404375 localhost-1 titanus g1
000404376 localhost-5 titanus g1
000404377 localhost-3 titanus g1
000404378 localhost-4 titanus g1
000404391 failover titanus failover
Preventing jobs from running on the candidate machine eliminates the risks of machine stability being affected by demanding jobs. The -failover option also enables some failover configuration validation checks. Finally, failover taskers are started before the regular queue taskers, which helps ensure a failover tasker is available as soon as possible for future failover events.
Refer to the tasker definition documentation for details on the -failover option.
Configure, Manage and Run Accelerator
Configure the Network, License and Security
Configure Monitoring of Software Utilization
Hierarchical Scheduling
License Allocation across Enterprise
Hardware Emulator Resource Optimizer
