Antenna Coupling Using an Equivalent Source and Ideal Receiving Antenna
Calculate the coupling between two horn antennas separated by 60 wavelengths. A metallic plate between the horn antennas blocks the line-of-sight coupling. Replace the horn antennas with a far field equivalent source and ideal far field receiving antenna.
- Pyramidal_Horn.cfx: Model of the horn antenna on its own. The far field pattern will be used in the equivalent source and ideal receiving antenna.
- Full_Model.cfx: Full model of two horn antennas and plate.
- Point_Source_Coupling.cfx: Model that calculates the antenna coupling using the far field equivalent source and ideal receiving antenna.
Figure 1. The model using equivalent source and receiving antenna.
