Altair Feko  2022.1.2 Documentation
  1. Home
  2. Examples
    The Feko Example Guide contains a collection of examples that teaches you Feko concepts and essentials.
  3. Antenna Synthesis and Analysis
    Simple examples demonstrating antenna synthesis and analysis.
  4. Periodic Boundary Conditions for Array Analysis
    Calculate the far field pattern for a single element in an infinite two-dimensional array of pin-fed patch elements. The infinite patch array is modelled using periodic boundary condition. Calculate the approximated far field pattern for a 10x10 element array.
  5. Pin-Fed Patch: Squint Pattern by Phase Shift Definition
    Compute the squint pattern for a single element in an infinite patch array and for a 10x10 element array. The phase shift is specified in the u1 and u2 vector directions.
  6. Defining Calculation Requests
    Define the calculation requests in CADFEKO.
  • Release Notes
  • Get Started
  • Examples
  • Introduction to Feko
  • CADFEKO
  • POSTFEKO
  • EDITFEKO
  • Feko Solution Methods
  • Optimisation in Feko
  • Feko Utilities
  • Description of the Output File of Feko
  • Feko Application Macros
  • Scripts and Application Programming Interface (API)
  • Appendix
Index
  • Release Notes
  • Get Started
  • Examples
    • Antenna Synthesis and Analysis
      • Dipole
        Calculate the radiation pattern and input impedance for a half-wavelength dipole at 74.9 MHz. The dipole length is 2 m with a wire radius of 2 mm.
      • Dipole in Front of a Cube
        Calculate the radiation pattern for a half-wavelength dipole in front of a cuboid. View the effect of the cuboid on the radiation pattern.
      • Dipole in Front of a Plate
        Calculate the radiation pattern of a dipole in front of an electrically large plate. Several techniques available in Feko are considered and the results and resource requirements compared.
      • Monopole Antenna on a Finite Ground Plane
        Calculate the radiation pattern for a wire monopole antenna on a finite ground plane. The ground plane is modelled as a circular PEC ground plane.
      • Yagi-Uda Antenna Above a Real Ground
        Calculate the radiation pattern for a horizontally polarised Yagi-Uda antenna consisting of a dipole, a reflector and three directors at 400 MHz. The antenna is located 3 m above a real ground which is modelled with the Green’s function formulation.
      • Pattern Optimisation of a Yagi-Uda Antenna
        Optimise a Yagi-Uda antenna design to achieve a specific radiation pattern and gain at 1 GHz. The Yagi-Uda antenna consists of a dipole, reflector and two directors.
      • Log Periodic Dipole Array Antenna
        Calculate the radiation pattern and input impedance for a log periodic dipole array (LPDA) antenna. Non-radiating transmission lines are used to model the boom of the LPDA antenna.
      • Microstrip Patch Antenna
        Model a microstrip patch antenna using two feed methods (pin feed, microstrip edge feed). The dielectric substrate is considered as a finite substrate and an infinite planar multilayer substrate.
      • Proximity Coupled Patch Antenna with Microstrip Feed
        Calculate the input reflection coefficient of a proximity coupled patch antenna on an infinite substrate.
      • Aperture Coupled Patch Antenna
        Calculate the input reflection coefficient of an aperture coupled patch antenna. Use continuous frequency sampling to minimise runtime. Compare results for a finite and infinite dielectric.
      • Different Ways to Feed a Horn Antenna
        Calculate the far field pattern of a pyramidal horn antenna at 1.645 GHz.
      • Dielectric Resonator Antenna on Finite Ground
        Calculate the input impedance and radiation pattern of a dielectric resonator antenna (DRA) with a coaxial pin feed on a finite ground.
      • Dielectric Lens Antenna
        Calculate the radiation pattern of a dielectric lens antenna. The lens is illuminated by an equivalent far field source with an ideal cosine pattern. The lens structure is modelled using the ray launching geometrical optics (RL-GO). Compare the RL-GO solution with a hybrid FEM/MoM solution.
      • Windscreen Antenna on an Automobile
        Calculate the input impedance of a windscreen antenna constructed with wires. The windscreen consists of a layer of glass and a layer of foil.
      • MIMO Elliptical Ring Antenna (Characteristic Modes)
        Calculate the current distribution and far fields for a MIMO elliptical ring antenna. Use characteristic mode analysis to calculate the results for different modes.
      • Periodic Boundary Conditions for Array Analysis
        • Pin-Fed Patch: Broadside Pattern by Phase Shift Definition
          Compute the broadside pattern for a single element in an infinite patch array and for a 10x10 element array. The phase shift is specified in the u1 and u2 vector directions.
        • Pin-Fed Patch: Broadside Pattern by Squint Angle Definition
          Compute the broadside pattern for a single element in an infinite patch array and for a 10x10 element array. The phase shift is determined from the direction into which the beam is pointing (“squint angle”).
        • Pin-Fed Patch: Squint Pattern by Phase Shift Definition
          • Creating the Model
            Create the model in CADFEKO. Define any ports and sources required for the model. Specify the operating frequency or frequency range for the model.
          • Defining Calculation Requests
          • Modifying the Auto-Generated Mesh
            Modify the model mesh in CADFEKO using the correct settings. A mesh is a discretised representation of a geometry model or mesh model used for simulation in the Solver.
          • Running the Feko Solver
            Run the Solver to compute the calculation requests.
        • Pin-Fed Patch: Squint Pattern by Squint Angle Definition
          Compute the broadside pattern for a single element in an infinite patch array as well for a 10x10 element array. The phase shift is determined from the direction into which the beam is pointing (“squint angle”).
        • Viewing the Results
          View and post-process the results in POSTFEKO.
      • Finite Antenna Array with Non-Linear Spacing
        Calculate the radiation pattern for an array of arbitrarily placed pin-fed patch antennas. Use the finite array tool to construct the array and the domain Green's function method (DGFM) to minimize computational resources.
    • Antenna Placement
      Simple examples demonstrating antenna placement.
    • Radar Cross Section (RCS)
      Simple examples demonstrating radar cross section (RCS) calculations of objects.
    • EMC Analysis and Cable Coupling
      Simple examples demonstrating electromagnetic compatibility (EMC) analysis and cable coupling.
    • Waveguide and Microwave Circuits
      Simple examples demonstrating using waveguides and microwave circuits.
    • Bio Electromagnetics
      Simple examples demonstrating phantom and tissue exposure analsysis.
    • Time Domain
      A simple example demonstrating the time analysis of an incident plane wave on an obstacle.
    • Special Solution Methods
      Simple examples demonstrating using continuous frequency range, using the MLFMM for large models, using the LE-PO (large element physical optics) on subparts of the model and optimising the waveguide pin feed location.
    • User Interface Tools
      Simple examples demonstrating using Feko application automation, matching circuit generation with Optenni Lab and optimising a bandpass filter with HyperStudy.
  • CADFEKO
  • POSTFEKO
  • EDITFEKO
  • Feko Utilities
  • Appendix
  1. Home
  2. Examples
  • Release Notes
  • Get Started
  • Examples
  • CADFEKO
  • POSTFEKO
  • EDITFEKO
  • Feko Utilities
  • Appendix
Index
Use the same calculation requests as for Pin-Fed Patch: Broadside Pattern by Phase Shift Definition.
