Calculate the radiation pattern of a dipole in front of an electrically large plate. Several techniques available
in Feko are considered and the results and resource requirements compared.
Calculate the radiation pattern for a horizontally polarised Yagi-Uda antenna consisting of a dipole, a reflector and three directors at 400 MHz. The antenna is located 3 m above a real
ground which is modelled with the Green’s function formulation.
Optimise a Yagi-Uda antenna design to achieve a specific radiation pattern and gain at 1 GHz. The Yagi-Uda antenna consists of a dipole, reflector and two directors.
Calculate the radiation pattern and input impedance for a log periodic dipole array (LPDA) antenna. Non-radiating
transmission lines are used to model the boom of the LPDA antenna.
Model a microstrip patch antenna using two feed methods (pin feed, microstrip edge feed). The dielectric substrate
is considered as a finite substrate and an infinite planar multilayer substrate.
Calculate the input reflection coefficient of an aperture coupled patch antenna. Use continuous frequency sampling
to minimise runtime. Compare results for a finite and infinite dielectric.
Calculate the radiation pattern of a dielectric lens antenna. The lens is illuminated by an equivalent far field source
with an ideal cosine pattern. The lens structure is modelled using the ray launching geometrical optics (RL-GO). Compare the RL-GO solution with a hybrid FEM/MoM solution.
Calculate the current distribution and far fields for a MIMO elliptical ring antenna. Use characteristic mode analysis
to calculate the results for different modes.
Calculate the far field pattern for a single element in an infinite two-dimensional array of pin-fed patch elements.
The infinite patch array is modelled using periodic boundary condition. Calculate the approximated far field pattern
for a 10x10 element array.
Compute the broadside pattern for a single element in an infinite patch array and for a 10x10 element array. The phase
shift is specified in the u1 and u2 vector directions.
shift is determined from the direction into which the beam is pointing (“squint angle”).
Compute the squint pattern for a single element in an infinite patch array and for a 10x10 element array. The phase
Compute the broadside pattern for a single element in an infinite patch array as well for a 10x10 element array. The
phase shift is determined from the direction into which the beam is pointing (“squint angle”).
Calculate the radiation pattern for an array of arbitrarily placed pin-fed patch antennas. Use the finite array tool
to construct the array and the domain Green's function method (DGFM) to minimize computational resources.
Simple examples demonstrating using continuous frequency range, using the MLFMM for large models, using the LE-PO
(large element physical optics) on subparts of the model and optimising the waveguide pin feed location.
Simple examples demonstrating using Feko application automation, matching circuit generation with Optenni Lab and optimising a bandpass filter with HyperStudy.
Feko is a comprehensive electromagnetic solver with multiple solution methods that is used for electromagnetic field analyses
involving 3D objects of arbitrary shapes.
EDITFEKO is used to construct advanced models (both the geometry and solution requirements) using a high-level scripting language
which includes loops and conditional statements.
Feko offers state-of-the-art optimisation engines based on generic algorithm (GA) and other methods, which can be used
to automatically optimise the design and determine the optimum solution.
CADFEKO and POSTFEKO have a powerful, fast, lightweight scripting language integrated into the application allowing you to create
models, get hold of simulation results and model configuration information as well as manipulation of data and automate
repetitive tasks.
