Altair Feko  2022.1.2 Documentation
  1. Home
  2. Examples
    The Feko Example Guide contains a collection of examples that teaches you Feko concepts and essentials.
  3. Antenna Synthesis and Analysis
    Simple examples demonstrating antenna synthesis and analysis.
  4. Dipole in Front of a Plate
    Calculate the radiation pattern of a dipole in front of an electrically large plate. Several techniques available in Feko are considered and the results and resource requirements compared.
  5. Dipole in Front of a Plate with FDTD
    Simulate the dipole and rectangular plate using finite difference time domain (FDTD).
  6. Defining Calculation Requests
    Define the calculation requests in CADFEKO.
  • Release Notes
  • Get Started
  • Examples
  • Introduction to Feko
  • CADFEKO
  • POSTFEKO
  • EDITFEKO
  • Feko Solution Methods
  • Optimisation in Feko
  • Feko Utilities
  • Description of the Output File of Feko
  • Feko Application Macros
  • Scripts and Application Programming Interface (API)
  • Appendix
Index
  • Release Notes
  • Get Started
  • Examples
    • Antenna Synthesis and Analysis
      • Dipole
        Calculate the radiation pattern and input impedance for a half-wavelength dipole at 74.9 MHz. The dipole length is 2 m with a wire radius of 2 mm.
      • Dipole in Front of a Cube
        Calculate the radiation pattern for a half-wavelength dipole in front of a cuboid. View the effect of the cuboid on the radiation pattern.
      • Dipole in Front of a Plate
        • Dipole in Front of a Plate with MoM
          Create the dipole and the rectangular plate. Solve the model using the method of moments (MoM).
        • Dipole in Front of a Plate with HOBF
          Create the dipole and the rectangular plate. Solve the model using the MoM with higher order basis functions (HOBF).
        • Dipole in Front of a Plate with FDTD
          • Creating the Model
            Create the model in CADFEKO. Define any ports and sources required for the model. Specify the operating frequency or frequency range for the model.
          • Defining Calculation Requests
          • Modifying the Auto-Generated Mesh
            Modify the model mesh in CADFEKO using the correct settings. A mesh is a discretised representation of a geometry model or mesh model used for simulation in the Solver.
          • Running the Feko Solver
            Run the Solver to compute the calculation requests.
        • Dipole in Front of a Plate with UTD
          Simulate the dipole with method of moments (MoM) and the rectangular plate using uniform theory of diffraction (UTD).
        • Dipole in Front of a Plate with RL-GO
          Simulate the dipole with method of moments (MoM) and the rectangular plate using ray launching geometrical optics (RL-GO).
        • Dipole in Front of a Plate with PO
          Simulate the dipole with method of moments (MoM) and the rectangular plate using physical optics (PO).
        • Dipole in Front of a Plate with LE-PO
          Simulate the dipole with method of moments (MoM) and the rectangular plate using large element physical optics (LE-PO).
        • Viewing the Results
          View and post-process the results in POSTFEKO.
      • Monopole Antenna on a Finite Ground Plane
        Calculate the radiation pattern for a wire monopole antenna on a finite ground plane. The ground plane is modelled as a circular PEC ground plane.
      • Yagi-Uda Antenna Above a Real Ground
        Calculate the radiation pattern for a horizontally polarised Yagi-Uda antenna consisting of a dipole, a reflector and three directors at 400 MHz. The antenna is located 3 m above a real ground which is modelled with the Green’s function formulation.
      • Pattern Optimisation of a Yagi-Uda Antenna
        Optimise a Yagi-Uda antenna design to achieve a specific radiation pattern and gain at 1 GHz. The Yagi-Uda antenna consists of a dipole, reflector and two directors.
      • Log Periodic Dipole Array Antenna
        Calculate the radiation pattern and input impedance for a log periodic dipole array (LPDA) antenna. Non-radiating transmission lines are used to model the boom of the LPDA antenna.
      • Microstrip Patch Antenna
        Model a microstrip patch antenna using two feed methods (pin feed, microstrip edge feed). The dielectric substrate is considered as a finite substrate and an infinite planar multilayer substrate.
      • Proximity Coupled Patch Antenna with Microstrip Feed
        Calculate the input reflection coefficient of a proximity coupled patch antenna on an infinite substrate.
      • Aperture Coupled Patch Antenna
        Calculate the input reflection coefficient of an aperture coupled patch antenna. Use continuous frequency sampling to minimise runtime. Compare results for a finite and infinite dielectric.
      • Different Ways to Feed a Horn Antenna
        Calculate the far field pattern of a pyramidal horn antenna at 1.645 GHz.
      • Dielectric Resonator Antenna on Finite Ground
        Calculate the input impedance and radiation pattern of a dielectric resonator antenna (DRA) with a coaxial pin feed on a finite ground.
      • Dielectric Lens Antenna
        Calculate the radiation pattern of a dielectric lens antenna. The lens is illuminated by an equivalent far field source with an ideal cosine pattern. The lens structure is modelled using the ray launching geometrical optics (RL-GO). Compare the RL-GO solution with a hybrid FEM/MoM solution.
      • Windscreen Antenna on an Automobile
        Calculate the input impedance of a windscreen antenna constructed with wires. The windscreen consists of a layer of glass and a layer of foil.
      • MIMO Elliptical Ring Antenna (Characteristic Modes)
        Calculate the current distribution and far fields for a MIMO elliptical ring antenna. Use characteristic mode analysis to calculate the results for different modes.
      • Periodic Boundary Conditions for Array Analysis
        Calculate the far field pattern for a single element in an infinite two-dimensional array of pin-fed patch elements. The infinite patch array is modelled using periodic boundary condition. Calculate the approximated far field pattern for a 10x10 element array.
      • Finite Antenna Array with Non-Linear Spacing
        Calculate the radiation pattern for an array of arbitrarily placed pin-fed patch antennas. Use the finite array tool to construct the array and the domain Green's function method (DGFM) to minimize computational resources.
    • Antenna Placement
      Simple examples demonstrating antenna placement.
    • Radar Cross Section (RCS)
      Simple examples demonstrating radar cross section (RCS) calculations of objects.
    • EMC Analysis and Cable Coupling
      Simple examples demonstrating electromagnetic compatibility (EMC) analysis and cable coupling.
    • Waveguide and Microwave Circuits
      Simple examples demonstrating using waveguides and microwave circuits.
    • Bio Electromagnetics
      Simple examples demonstrating phantom and tissue exposure analsysis.
    • Time Domain
      A simple example demonstrating the time analysis of an incident plane wave on an obstacle.
    • Special Solution Methods
      Simple examples demonstrating using continuous frequency range, using the MLFMM for large models, using the LE-PO (large element physical optics) on subparts of the model and optimising the waveguide pin feed location.
    • User Interface Tools
      Simple examples demonstrating using Feko application automation, matching circuit generation with Optenni Lab and optimising a bandpass filter with HyperStudy.
  • CADFEKO
  • POSTFEKO
  • EDITFEKO
  • Feko Utilities
  • Appendix
  1. Home
  2. Examples
  • Release Notes
  • Get Started
  • Examples
  • CADFEKO
  • POSTFEKO
  • EDITFEKO
  • Feko Utilities
  • Appendix
Index
Use the same calculation requests from the Dipole in Front of a Plate with MoM model.
