Modifying the Auto-Generated Mesh
Modify the model mesh in CADFEKO using the correct settings. A mesh is a discretised representation of a geometry model or mesh model used for simulation in the Solver.
Use the same mesh settings as for Dipole in Front of a Plate with MoM.
Note: No mesh triangles are created. Feko applies the UTD solution to the plate surface.
