Dielectric Resonator Antenna on Finite Ground
Calculate the input impedance and radiation pattern of a dielectric resonator antenna (DRA) with a coaxial pin feed on a finite ground.
- Feed with a FEM modal source and solve using the hybrid finite element (FEM) and MoM solution.
- Feed with a waveguide source and solve using the method of moments (MoM) solution with the surface equivalence principle (SEP).
Figure 1. 3D view of the dielectric resonator antenna on a finite ground plane.
