Pin-Fed, Planar Multilayer Substrate Model
Model a microstrip patch antenna using a feed pin and a planar multilayer substrate (Green’s functions). The patch antenna is solved with MoM.
Figure 1. A 3D view of the pin-fed microstrip patch antenna on an infinite ground.
