Creating the Model
Create the model in CADFEKO. Define any ports and sources required for the model. Specify the operating frequency or frequency range for the model.
Note: Assume the focal point of the lens is located at the global origin.
Define the following variables.
- freq = 30e9 (The operating frequency.)
- epsr = 6 (relative permittivity.)
- tand = 0.005 (dielectric loss tangent.)
- lambda_0 = c0/freq (The wavelength in free space.)
- D = lambda_0*10 (lens diameter.)
- F = 1.5*D (focal length.)
Define the following derived variables for the model construction.
- alpha = arcsin(D/(2*F)) (The included angle to the edge of the lens.)
- arclength = alpha* F (The arc length to the edge of the lens.)
- n = sqrt(epsr) (The refraction index of the lens.)
- T = (2*F - sqrt(4*F^2 - D^2))/(2*(n-1)) (The thickness of the length.)
- v0 = (F + T) / (n + 1) (The ellipse offset distance.)
- u0 = sqrt(n^2 - 1) * v0 (The diameter of the lens.)
- w0 = n*v0 (The major axis length of the ellipse.)
Define a dielectric medium, glass.
- Relative permittivity: epsr
- Dielectric Loss tangent: tand
- Label: Glass
Construct the lens by subtracting a sphere from an elliptical spheroid.
Create a sphere.
- Definition method: Centre, radius
- Centre: (0, 0, 0)
- Radius: F
Create the elliptical spheroid.
Create a sphere.
- Definition method: Centre, radius U, radius V, radius N
- Centre: (0, 0, v0)
- Radius (Ru): u0
- Radius (Rv): u0
- Radius (Rn): w0
Create a sphere.
Subtract the sphere from the elliptical spheroid.
- Rename Subtract1 to Lens.
A closed region is by default set to perfect electric conductor (PEC).
- Set the region of Lens to Glass.
Set the solver method for the dielectric lens antenna to use RL-GO.
Tip: Open the Modify Face dialog and click the Solution tab. From the Solve with special solution method list, select Ray launching - geometrical optics (RL-GO).
- Set the frequency to freq.
The dielectric lens is illuminated by a far field pattern source. The E-field pattern is described by the following equation.
Define the far field data.
- Load field data from a Feko Solver (*.ffe) file
- File name: Ideal_CosineQ4_Xpol.ffe
- Select Use all data blocks
- Label: FarFieldData1
Create a far field equivalent source using the far field definition,
FarFieldData1.
- Magnitude scale factor: 1
- Phase offset (degrees): 0
- Field data: FarFieldData1.
Note: The far field source is positioned at the origin which coincides with the focal point of the lens.
