Creating the Model
Create the model in CADFEKO. Define any ports and sources required for the model. Specify the operating frequency or frequency range for the model.
Simple examples demonstrating antenna synthesis and analysis.
Simple examples demonstrating antenna placement.
Simple examples demonstrating radar cross section (RCS) calculations of objects.
Calculate the bistatic radar cross section of an electrically thin dielectric sheet. The sheet is modelled using the thin dielectric sheet approximation and is illuminated by an incident plane wave.
Calculate the radar cross section and the near field inside and outside of a dielectric sphere using the surface equivalence principle (SEP).
Define the calculation requests in CADFEKO.
Modify the model mesh in CADFEKO using the correct settings. A mesh is a discretised representation of a geometry model or mesh model used for simulation in the Solver.
Run the Solver to compute the calculation requests.
View and post-process the results in POSTFEKO.
Calculate the scattering width of an infinite cylinder. The infinite cylinder is modelled using an one-dimensional periodic boundary condition (PBC).
Calculate the transmission and reflection coefficients for a Jerusalem cross FSS (frequency selective surface) structure. The cross is modelled with a periodic boundary condition and is excited with an incident plane wave.
Calculate the transmission coefficient of a second order, electrically thin bandpass FSS (frequency selective surface) structure. The structure is modelled with a periodic boundary condition and is excited with an incident plane wave.
Simple examples demonstrating electromagnetic compatibility (EMC) analysis and cable coupling.
Simple examples demonstrating using waveguides and microwave circuits.
Simple examples demonstrating phantom and tissue exposure analsysis.
A simple example demonstrating the time analysis of an incident plane wave on an obstacle.
Simple examples demonstrating using continuous frequency range, using the MLFMM for large models, using the LE-PO (large element physical optics) on subparts of the model and optimising the waveguide pin feed location.
Simple examples demonstrating using Feko application automation, matching circuit generation with Optenni Lab and optimising a bandpass filter with HyperStudy.
