Modifying the Auto-Generated Mesh
Modify the model mesh in CADFEKO using the correct settings. A mesh is a discretised representation of a geometry model or mesh model used for simulation in the Solver.
Simple examples demonstrating antenna synthesis and analysis.
Simple examples demonstrating antenna placement.
Simple examples demonstrating radar cross section (RCS) calculations of objects.
Simple examples demonstrating electromagnetic compatibility (EMC) analysis and cable coupling.
Simple examples demonstrating using waveguides and microwave circuits.
Simple examples demonstrating phantom and tissue exposure analsysis.
A simple example demonstrating the time analysis of an incident plane wave on an obstacle.
Simple examples demonstrating using continuous frequency range, using the MLFMM for large models, using the LE-PO (large element physical optics) on subparts of the model and optimising the waveguide pin feed location.
Calculate the input admittance for a simple forked dipole.
Consider the resource saving advantage of using the MLFMM for electrically large models
Calculate the gain for a cylindrical horn feeding a parabolic reflector at 12.5 GHz. The reflector is electrically large (diameter of 36 wavelengths) and well separated from the horn. Several techniques available in Feko are considered to reduce the required resources for electrically large models.
Create the horn and the parabolic reflector. Solve the horn using MoM and the reflector using LE-PO.
Create the model in CADFEKO. Define any ports and sources required for the model. Specify the operating frequency or frequency range for the model.
Define the calculation requests in CADFEKO.
Run the Solver to compute the calculation requests.
Solve the horn using MLFMM and the reflector using PO.
Solve the horn using MLFMM and the reflector using LE-PO.
Calculate the fields of only the horn antenna. Export the fields to file for usage in an equivalent source.
Solve the horn using an equivalent near field source and the reflector using LE-PO.
Solve the horn using a spherical modes source and the reflector using LE-PO.
Compare the resource requirements and far field gain patterns for the models using different solver techniques.
Analyse the effect of the pin offset on the reflection coefficient using an optimisation grid search and the NGF solution settings.
Use characterised surfaces with ray launching geometrical optics (RL-GO) for an efficient solution of a frequency selective surface (FSS).
Simple examples demonstrating using Feko application automation, matching circuit generation with Optenni Lab and optimising a bandpass filter with HyperStudy.
