Adding an Optimisation Search
Add an optimisation search.
  1. Add an optimisation search. Use the Grid search method and Default number of points equal to 15.
  2. Specify the optimisation parameters.
    1. Define the variable to be optimised.
      Variable Min value Max value Start value Grid points
      n 1 15 Empty 15
  3. Define an Impedance goal to minimise the magnitude of the reflection coefficient for VoltageSource1.
