Changing the Axes of the Trace (Independent and Fixed)
Set the independent axis of the far field trace to Phi and the fixed axis to Theta = 30°.
myFarFieldTrace.IndependentAxis = "Phi" myFarFieldTrace:SetFixedAxisValue("Theta",30, "deg")
Simple examples demonstrating antenna synthesis and analysis.
Simple examples demonstrating antenna placement.
Simple examples demonstrating radar cross section (RCS) calculations of objects.
Simple examples demonstrating electromagnetic compatibility (EMC) analysis and cable coupling.
Simple examples demonstrating using waveguides and microwave circuits.
Simple examples demonstrating phantom and tissue exposure analsysis.
A simple example demonstrating the time analysis of an incident plane wave on an obstacle.
Simple examples demonstrating using continuous frequency range, using the MLFMM for large models, using the LE-PO (large element physical optics) on subparts of the model and optimising the waveguide pin feed location.
Simple examples demonstrating using Feko application automation, matching circuit generation with Optenni Lab and optimising a bandpass filter with HyperStudy.
Use application automation to perform operations with CADFEKO and POSTFEKO. Typical tasks include repetitive tasks, tasks that require several steps, or calculations.
Learn the terminology of automation to create an automation script.
Learn to navigate the API documentation to find the correct syntax for an automation script.
Learn to navigate the API documentation to create a patch antenna using an automation script.
Post-process the results of a patch antenna on a multilayer substrate.
Define a new POSTFEKO project and open a .fek file.
Get a “handle” on the far field result in the far field collection.
Create a Cartesian graph and add a far field result trace, change the independent and fixed axes, quantities and format the graph.
Add a Cartesian graph to the project.
Add a trace (for this example, a far field result) to a Cartesian graph.
Change the far field trace axis to dB.
Change the font size for both the vertical axis and horizontal axis to 12.
View the completed POSTFEKO automation script.
Increase productivity when dealing with predictable and repeatable POSTFEKO sessions (for example, exporting a report) using application automation. Use an automation script to configure a session and export a report that highlights the antenna properties of the model.
Design a bandpass coupled line filter with Altair HyperStudy as optimisation engine and Feko as the computational solver.
The result is then:
SetFixedAxisValue (axis string, numvalue number, unit string)
The result is then:
SetFixedAxisValue("Theta", 30, "deg")
:SetFixedAxisValue("Theta", 30, "deg")
myFarFieldTrace:SetFixedAxisValue("Theta", 30, "deg")
