Simple examples demonstrating using continuous frequency range, using the MLFMM for large models, using the LE-PO
(large element physical optics) on subparts of the model and optimising the waveguide pin feed location.
Simple examples demonstrating using Feko application automation, matching circuit generation with Optenni Lab and optimising a bandpass filter with HyperStudy.
Use application automation to perform operations with CADFEKO and POSTFEKO. Typical tasks include repetitive tasks, tasks that require several steps, or calculations.
Create a planar multilayer substrate using the properties method that contains two layers. Layer 1 is set to substrate2 and Layer2 is set to substrate1. The second layer has a PEC ground plane.
Create a far field request (0°≤θ≤90°, with 0°≤ϕ≤360°).Sample the far field at θ=5° and ϕ=5° steps. The far field request is added to the default configuration, StandardConfiguration1.
Increase productivity when dealing with predictable and repeatable POSTFEKO sessions (for example, exporting a report) using application automation. Use an automation script to configure a
session and export a report that highlights the antenna properties of the model.
Feko is a comprehensive electromagnetic solver with multiple solution methods that is used for electromagnetic field analyses
involving 3D objects of arbitrary shapes.
EDITFEKO is used to construct advanced models (both the geometry and solution requirements) using a high-level scripting language
which includes loops and conditional statements.
Feko offers state-of-the-art optimisation engines based on generic algorithm (GA) and other methods, which can be used
to automatically optimise the design and determine the optimum solution.
CADFEKO and POSTFEKO have a powerful, fast, lightweight scripting language integrated into the application allowing you to create
models, get hold of simulation results and model configuration information as well as manipulation of data and automate
repetitive tasks.
Creating a Planar Multilayer Substrate
Creating the Feed Line
Create a feed line with start point (0, 0, 0) , end point (0, 0, -0.551) and label Feedline.
Unioning the Model
Union all geometry in the model (Feedline and Patch) and set its label to Union1.
Defining a Far Field Request Create a far field request (0°≤θ≤90°, with 0°≤ϕ≤360°).Sample the far field at θ=5° and ϕ=5° steps. The far field request is added to the default configuration, StandardConfiguration1.
Defining a Current Request
Create a currents request. The currents request is added for the default configuration, StandardConfiguration1.
