Running the Solver
Run the Solver by searching and navigating the documentation. Enable a parallel solution, save the model and run the Solver.
  1. Search for runfeko in the integrated help.
The results return in response to the runfeko query includes RunFEKO (method).
  1. Double-click RunFEKO (method).
    The Choose Topic dialog is displayed.
  2. Double-click on either of the Launcher on the Choose Topic dialog.
  3. View the :RunFEKO method.
    Figure 1. A snippet of the Launcher object which shows the :RunFEKO method.
  4. Run the Solver using the following syntax:
    my_project.Launcher:RunFEKO()
