Automatic Report Generation Using API
Increase productivity when dealing with predictable and repeatable POSTFEKO sessions (for example, exporting a report) using application automation. Use an automation script to configure a session and export a report that highlights the antenna properties of the model.
Note: The script can be used on various models with repeatable results.
Figure 1. Results of the automatic report generation for two different antenna types.
