Using Altair HyperStudy with Feko to Optimise a Bandpass Filter
Design a bandpass coupled line filter with Altair HyperStudy as optimisation engine and Feko as the computational solver.
The design aims to obtain the best spacings for S1 - S3 in the depiction of the geometry below. The spacings are optimised to maximize the coupling between the input and output ports within the operating frequency range.
Figure 1. Top view of the bandpass filter.
Note: The parametric model is provided for convenience. For the sake of simplicity, the cutoff frequencies and out-of-band performance will not be considered for the design.
