Viewing the Input Reflection Coefficient
View the input reflection coefficient on a Cartesian graph in dB.
  1. On the Home tab, in the Create new display group, click the  Cartesian icon.
  2. On the Home tab, in the Add results group, click the  Source data icon. From the drop-down list, select VoltageSource1.
  3. View the input reflection coefficient in dB versus frequency.
    1. On the result palette, in the Traces panel, select VoltageSource1.
    2. On the Quantity panel, confirm that Reflection coefficient is selected (default option).
    3. On the Quantity panel, select the dB check box.
    Figure 1. The result palette containing the Traces, Source, Slice and Quantity panels (listed from top to bottom).
  4. Change the legend position to bottom-right.
    1. On the Display tab, in the Display group, click the  Position icon. From the drop-down list select Overlay bottom right.
  5. Remove the graph footer.
    1. On the Display tab, in the Display group, click the  Chart text icon.
    2. In the Graph footer field, clear the Auto check box and delete the text.
    3. Click OK to apply the text changes and to close the dialog.
    Figure 2. The input reflection coefficient in dB versus frequency.
