Topics Discussed in Example
Before starting this example, check if the topics discussed in this example are relevant to the intended application and experience level.
- CADFEKO
- Activate macro recording of a model.
- Changing the model unit.
- Create and group variables.
- Create a dielectric.
- Create geometry (polygon, cuboid and line).
- Set the region of a cuboid to dielectric.
- Set the faces of a dielectric cuboid to PEC1.
- Add a voltage source to a wire segment.
- Modify the auto-generated mesh.
- Add a far field request.
- Deactivate macro recording and run the resulting Feko Lua script.
- Run the Solver.
- POSTFEKO
- View the input reflection coefficient on a Cartesian graph.
- View the left-hand and right-hand circular components of the far field on a Cartesian graph.
