Adding a Voltage Source
Add a voltage source to the port of the pin.
  1. On the Source/Load tab, in the Sources on Ports group, click the  Voltage Source icon.
  2. On the Add Voltage Source dialog, use the default settings.
    Figure 1. The Create Voltage Source dialog.
  3. Click Create to define the voltage source and to close the dialog.
    Note: The Configuration tab was selected automatically when you defined the voltage source. You may also add sources, loads and set the frequency from here.
