Change the region property of the substrate to dielectric.
In the model tree, select
substrate.
In the details tree, under Regions,
select Region1.
From the right-click context menu, select
Properties.
Figure 1. The right-click context menu options available for
regions.
On the Modify Region dialog
(Properties tab), set Medium
to Ceramic.
Figure 2. The Modify Region dialog.
Tip: Simplify workflow by using
Create new to define items when needed.
Click OK to modify the region property and to
close the dialog.
Note: The
icon in the
model tree and
details tree indicate items set to dielectric.
