The monopole and transmission line are each assigned a different wire radius. Due to
the differences in the wire radii, we specify a local wire radius for the
monopole.
Note: Local mesh refinement takes precedence over global mesh
settings.
In the model tree (Construction tab), select
Monopole. In the details tree, select
Edge1.
From the right-click context menu, select
Properties.
On the Modify Edge dialog
(Properties tab), specify the following:
Select the Local wire radius check box.
Set the Radius to
0.015.
Figure 1. The Modify Edge dialog.
Click OK to apply the
properties and to close the dialog.
Note: The icon in the details tree indicate that
a local wire radius is applied.
