Define a wire port on the monopole. A voltage source will be added to this
port.
Select the monopole using one of the following workflows:
- Click on the monopole in the 3D view.
- In the model tree, select
Monopole. In the details tree, select Edge1.
Define the wire port on the selected wire (monopole) using one of the following
workflows:
- On the Source/Load tab, in the
Ports group, click the Wire Port icon.
- On the details tree, a right-click context menu is available on the edge. Click .
Use the default port settings.
Click Create to create the port and close the
dialog.
