Setting Local Mesh Sizes for Waveguide Port Faces
Refine the mesh locally at the waveguide port faces. The faces for the waveguide ports require a finer mesh to represent the highest mode that should be taken into account. The higher order modes are typically evanescent modes.
Note: The icon in the details tree indicate that
a local mesh setting is applied.
