Specifying the Optimisation Parameters
Specify the optimisation parameters. Choose from existing variables and specify their minimum and maximum values
- In the model tree (Construction tab), select the relevant search. On the Request tab, in the Optimisation group, click the Parameters icon.
- On the Modify Optimisation Parameters dialog, click the Add button to add a second parameter.
Populate the fields on the Modify Optimisation Parameters
dialog as given in the table.
Variable Min value Max value Start value alpha 20 110 80 d 0.7 0.9 0.8 - Click OK to set the parameters and to close the dialog.
