Importing Array Parameters From File
Specify a file to import an array with a user-defined distribution, or to import an irregular-spaced array or both.
An application macro is a reference to an automation script, an icon file and associated metadata.
The application macro library allows commonly used application macros to be stored in a repository.
A collection of Lua application macros are available to automate repetitive tasks in CADFEKO.
This application macro transfers settings and application macros between different versions of Feko. This may be useful if you have customised one installation of Feko and want to use the same settings in a concurrent installation.
The application macro allows you to create an array of elements. Specify the number of elements and offset between the elements, or import the coordinates from file to create an irregular-spaced array. For the array amplitude distribution, select a mathematical distribution (such as cosine) or import the magnitude and phase for each element from file.
Use the application macro to create a linear or planar antenna array from a specified base element.
Use the application macro to create an irregular-spaced antenna array from a specified base element.
The Generate antenna array application macro has several limitations on how the base element is defined and the amplitude distribution.
The application macro allows you to compare two CADFEKO models to find the differences between the two models.
A collection of smaller CADFEKO application macros are available, but these macros do not include step-by-step instructions.
A collection of Lua application macros are available to automate repetitive tasks in POSTFEKO.
A collection of Lua macros are available to automate repetitive tasks where the workflow span both CADFEKO and POSTFEKO.
For example (if you use comma-separated values):
20, 30, 40, 1, 0
25, 30, 40, 2, 20
28, 30, 40, 5, 30
1, 0
2, 20
5, 30
Figure 2
illustrates the element order when importing the magnitude and phase
from a file.© 2022 Altair Engineering, Inc. All Rights Reserved.
