Processing the HRRP Results
Execute the PF_process_high_resolution_range_profile.lua application macro in POSTFEKO to process the far field data for the high-resolution range profile.
- Open Cylinder_HRRP_2D_sinogram.fek in POSTFEKO.
application macro in POSTFEKO.
The HRRP far field selection dialog is displayed.
- In the Select far field request drop-down list, select the Missle_RCS_Vpol_PO_HRRP.FarField1 far field data.
In the Window function
drop-down list, select one of the following:
- Select Rectangular, to use the rectangular (Dirichlet) window function.
- Select Hamming, to use the Hamming window function.
- Select Hamming_modified, to use a modified version of the Hamming window function.
- Select Gaussian, to use the Gaussian window function.
Specify the Sampling factor, to increase the image
resolution to create a smoother image with more points.
Note: The image resolution is related to the sampling factor as follows,
- Select the Reverse range check box to reverse the range when creating the graph.
Click OK to start processing the HRRP graphs.
View the generated results.
