Processing the HRRP Results
Execute the PF_process_high_resolution_range_profile.lua application macro in POSTFEKO to process the far field data for the high-resolution range profile.
- Open Cylinder__1D_profile.fek in POSTFEKO.
application macro in POSTFEKO.
The HRRP far field selection dialog is displayed.
Figure 1. The HRRP far field selection dialog. - In the Select far field request drop-down list, select the Cylinder__1D_profile.StandardConfiguration2_.FarField1 far field data.
In the Window function
drop-down list, select one of the following:
- Select Rectangular to use the rectangular (Dirichlet) window function.
- Select Hamming to use the Hamming window function.
- Select Hamming_modified to use a modified version of the Hamming window function.
- Select Gaussian to use the Gaussian window function.
Specify the Sampling factor to increase the image
resolution to create a smoother image with more points.
Note: The image resolution is related to the sampling factor as follows,
- Select the Reverse range check box to reverse the range when creating the graph.
Click OK to start processing the HRRP graph.
View the generated graph.Note: The label name includes the number of points used in the plot.
Figure 2. Example of a 1D profile using a rectangular window function with a sampling factor of 10. The polarisation angle is equal to 0°.
Figure 3. Example of a 1D profile using a rectangular window function with a sampling factor of 10. The polarisation angle is equal to 90°.
Figure 4. Example of an HRRP 2D sinogram using a sampling factor of 10, and the polarisation angle is equal to 0°.
