Example 2: Missile
In this example the view direction and cross-range resolution of the ISAR image is changed by using a subset of the angular data range. Some of the script's post-processing options are demonstrated.
An application macro is a reference to an automation script, an icon file and associated metadata.
The application macro library allows commonly used application macros to be stored in a repository.
A collection of Lua application macros are available to automate repetitive tasks in CADFEKO.
A collection of Lua application macros are available to automate repetitive tasks in POSTFEKO.
The MRI application macro computes , , their ratio and the intrinsic signal-to-noise ratio (ISNR) for magnetic resonance imaging (MRI) investigations in POSTFEKO.
The radiation phase centre is a useful quantity to calculate, especially for reflector antennas. The phase centre calculation is not available in Feko by default, but a stand-alone application macro is available that can be used to calculate the phase centre of a calculated far field.
This POSTFEKO application macro can be used to plot all the standard parameters that are available after a characteristic mode analysis simulation was performed.
This application macro is used for calculating mean effective gain (MEG) and envelope correlation coefficient (ECC) for a MIMO antenna configuration. The MEG ratio can also be plotted.
The Multiport post-processing application macro allows you to calculate results for changes in the port loading without rerunning the Solver. Results that are supported are far fields, near fields, currents and specific port parameters, for example, the voltage, current and S-parameters of each port.
Plot multiport S-parameter results.
This application macro computes and displays an inverse synthetic aperture radar (ISAR) image from backscattered radar cross-section (RCS) data.
The application macro computes and displays an inverse synthetic aperture radar (ISAR) image from the backscattered radar cross-section (RCS) data over frequency and angle.
Backscattered RCS data must be in the UV plane of the local coordinate system or the XY plane of the global coordinate system. Equivalently, the backscattered RCS should be requested in the cut. Sub-ranges of the total angular phi range could be used to change the viewing angle.
In this example the view direction of the ISAR image is changed using the local workplane of the incident plane wave excitation. It is also possible to change the view direction and cross-range resolution of the ISAR image by using a subset of the angular data range (see Example 2 below).
The images below show some results obtained by using different post-processing options available in the script.
A Lua implementation of the transient Pennes bioheat equation using finite differences and explicit time stepping for calculating thermal results in POSTFEKO.
An application macro to tile any POSTFEKO views side-by-side.
This application macro uses the S-parameter data from a Feko simulation to display a coupling matrix for a multi-port scenario.
The characteristic mode synthesis and design application macro is a post-processing application macro that can be used to calculate a weighted sum for the currents, near fields, and far fields requests for specific characteristic modes of interest. The application macro uses a modified version of the modal weighting coefficient (MWC) to use the radiating phase when synthesising the results with the macro.
A collection of smaller POSTFEKO application macro are available, but these macros do not include step-by-step instructions.
A collection of Lua macros are available to automate repetitive tasks where the workflow span both CADFEKO and POSTFEKO.
